Redex - Pre MOT to help lower emissions?
  Impreza Wagon
Every year my car seems to fail on emissions despite replacing various sensors. It's had a replacement CAT around 3 years ago so I'd also like to think that's ok.
I was wondering about dumping some Redex in this weekend and booking it in for Monday. I'm not sure this will make a difference but must be worth a go?
I suppose I'm hoping it'll pass but what would be the next steps if it fails again? Also it only ever fails by a small amount.
  Fiesta ST2 MP215
You doing the MOT on a hot engine, such as ragging it before the MOT, Cleaning the Cat out @7000RPM and 1000c?
  Impreza Wagon
Last year the garage had it for 2 days which consisted of spirited drives on the ring road and then testing. It helped to lower the emissions a little however it was still just failing. I'm not wanting to fork out for a new CAT however it seems like this could be the last resort if it fails next week.
  172 Cup
I think putting redex in for a series of weeks may make the difference if any!? I always throw it in anyway
  BG DCI
New garage?
It shouldn't be failing with a cat from new let alone a 3 year old one.
Are they reputable? Specialist? Halfrauds auto centre?
Might just be picky..
  182/RS2/ Turbo/Mk1
I dont think redex is likely to make a difference by the sounds of it you just have a cheap replacement cat that isnt very efficient?
But it depends a bit which emission test its actually failing on?
  Fiesta ST2 MP215
Changed plugs and leads prior to this? just to get it burning as clean as possible, I reckon an RStuner would help a lot, makes it run so much cleaner, my emissions were really good last time ( everything else was fucked though )
  182/RS2/ Turbo/Mk1
Its held at 3K at part throttle for the cat test, I dont see how an rs tuner will effect this, its on lambda control either way!
  Fiesta ST2 MP215
I just thought it made it run better as a whole, Surely better economy means more efficient fueling and thus cleaner emissions? although probably being a r****d here as I do have no idea how these things actually work
  182/RS2/ Turbo/Mk1
The standard car and the RS tuner one both run the same fuelling at part throttle at the point that the test is conducted mate. Its only one very narrow bit of the map that gets tested.
  Fiesta ST2 MP215
Oh right I see, I remember this coming up a while ago when you say that, same way pops and bangs crap doesn't affect it as under 4k. I will stay out now.
Dr HMS Derv Destroyer
  MK1DTi/vivaro/corsa
The guy I use for MOTs puts a cap full of this stuff into car oil if they don't pass. It somehow passes after that. Go figure...
Take it Fred's MOT guy.!
Usually aswell, if the filters on the emmisions machine is dirty it will make the reading higher
  Impreza Wagon
I'm pretty sure it's a cheap replacement as it only cost aprox £200, this was fitted prior to me buying it.
It's been mapped with an RS Tuner a while ago however I think that was after it's last MOT.
The garage I use is a local one that's MOT'd the family's cars for years so I trust them. The lad who works there spent hours tinkering with it so it just passed. Ideally I'd like to find the problem however a friendly MOT could end up being the answer.
  Impreza Wagon
That sounds like a trust worthy place :D
Matt, have you tried changing either of the lambda sensors?
I changed one last year (pre CAT?), the garage also did some tests swapping them around and it still made little/no difference.
  AB182, Audi A5 3.0
just to give you an idea, my 182 with original cat + RSTuner map passed just last week with these results:
engine speed: 2000-3000rpm
CO : 0.001% (limit 0.2%)
HC: 0ppm (limit <=200ppm)
lambda: 1.028 (limit 0.970-1.030)
  Impreza Wagon
It's going in on Monday to check the emissions before it get's MOT'd. I'll update with results then.....
  182/RS2/ Turbo/Mk1
That CO and HC dont seem realistic at all to me, did he yank the probe out for those tests?
  AB182, Audi A5 3.0
It might be possible the test didn't actually run on those I suppose? Just looked at my printout for the 100TCE and it shows the same for those two. I didn't see any probe yanking (thankfully).
  Impreza Wagon
It failed on the lambda reading, not sure by how much but all other readings are OK. It had a replacement sensor last year, is it worth changing it again? What could be another reason for it failing on this?
  182/RS2/ Turbo/Mk1
New lambda sensor is probably a good shout.
It could also be the CTS though, as it wont start using the Lambda till its upto temp.
  Clio
What about getting it terracleaned? apparently this can vastly reduce emissions, dont quote me on this, its not something I've ever done myself
  182/RS2/ Turbo/Mk1
His problem isnt emisisons as such, its the ECU not correctly following the lamda signal or the lamba signal being incorrect.
_Tom
Seeing this reminded me I watch something over the weekend where as they tested redex on a Corrado VR6. Before and after it actually gained 5bhp.
Edit. It was Fifth gear.
Maccy
  Straight 6
I saw this, I'll take that with a very large pinch of salt...
Then again, I think it's supposed to have better results with older engines.
_Tom
To be fair they did say it will probably work with an older engine. But some 182's have racked up the miles now.
  Impreza Wagon
Still failing! It either fails on lambda or C02 but not both. I'm feeling like it could be time for a special MOT....
Gally
You need to become friends with an mot tester mate. The Frp left the factory failing emissions testing even red hot...
I did here someone suggest using the probe on another car but that would be madness....
  DON'T SEND ME PM'S!!
what exhaust. if it's aftermarket, it will make a big difference which tailpipe they put the probe in depending on the design
  Clio Cup
Sometimes my MOT Tester absent mindedly connects it to the wrong car..................................................
  Lionel Richie
it can throw the emissions light on on ours and cause it to misfire! If its the old style yozza it doesn't matter
