Donny_Dog
Jim's rejects
Can anyone confirm I'm talking sense here? tried google, but nothing seems to tally with the problem I've just fixed and want to make sure I aint talking poo before presenting at our technical meeting.
We have two switches connected together (they're layer 3, with routing capabilities, so just say they are routers).
RIP V2 is used.
Router 1 - has a gigabit interface in network: 192.168.246.0/24
Router 1 - has a gigabit interface in network: 192.168.240.217/30 - this is the connection to router 2
Router 2 - has a gigabit interface in network 192.168.15.0/24
Router 2 - has a gigabit interface in network 192.168.240.218/30 - connection to router 1
What I wanted to do, was advertise the network 192.168.246.0 on router 1, with a higher metric - so that it would only populate the routing table should another lower metric route get removed (we have multiple routes to the 246 subnet).
on Router 1
Router rip
Version2
redistribute connected metric 7
network 192.168.240.0
When I did a 'show ip route 192.168.246.0' on router 2 - I was seeing the route with a metric of 2. NOT what we want.
I have summarised that: *(this is what i need confirmation on)
By using redistribute connected, we are saying that all interfaces should be redistributed with a metric of 7.
BUT by having the network statement in there, which is telling RIP to run on interfaces that are inside the classful networks listed (246 and 240), the routes from those interfaces will actually use a default metric, ignoring the generic redistribute command.
when i removed the network 192.168.246.0 statement - the route was actually added to the routing table with the correct metric - so the network command must over-ride the redistribute command if it is explicitly specified - you cannot define a metric for the network statements, so they will always use a default metric.
is that right?
RIP V2 is used.
on Router 1
Router rip
Version2
is that right?
