refurb side badges
Car  Clio II phase B Dynamique
plastics side of my clio were very discoloured ... and I thought refurb with the matt black spray ... someone has already done? there is a special procedure?
help...
depends if you still want that texture, "orange peel" effect, if you do, plastic primer 2 coats should do then 2 coats of matt black.
i dont think you need to laquer it, dont quote on me as it'll turn to gloss black.
matt effect lacquer :)
I would just make it dark again and then make them even harsh ... in that case can do only the primer and then paint their whit spray paint? and finally give a transparent protective? without any sandpaper work?
give them a quick sand down with 600 grit dnt need to be smooth just somat for the paint to stick to . then go to your local motorfactors and you can buy loads of diff colour bumper paints . think its somat like traffic black for clio's
thanks a lot... ;)
what about re spraying it to go back to silver?
Is that possible?
yeh there is a paint code on the back of the bullet . then just go to halfords and have some made up in a rattle can. dont use laquer tho if you want to keep the original finish
