remove plates help
Car  clio 172
has simple as it sounds i can not get the old number plates of for love or money wht an earth are they stuck on with any ideas i done want to prise them off with a screw driver cause of the paint work
if not screwed on (which i guess not for you!) then its just stick tape stuff! try heating it up with a hair dryer and pulling from one side, need a bit of force;)
screwdriver with a rag over it to save ur paint :rasp:
edit - yep that'll do
Have you got two little plastic pimples on either side of your number plate? If so then simply flip up the lid and unscrew.. However if you havnt then Id go with what Rob said and heat it up and prize off with a rag and a screwdriver :)
