Removing Airbag.
Car  Clio 172 Ph1.
Hi there.
i have removed all of the airbags exept for the one in the dash. This is going to be removed to. Instead of just using a resistor like i did with all the others, i was thinking of just removing the entire airbag system, crash sensors, ecu, and wires.
I will also remove the smd from the speedo.
Would i encounter any problems by doing this?
The car is a ph 1 172
