Mine work fine BUT I always have to tap the stalk down and up first time I start the car, after that they work fine and automatically adjust the wiping frequently to the amount of rain, stop and start when they should etc.
But if I don't tap the stalk the first time, they will just remain off even in heavy rain, is that a normal glitch with the Clio or just my car?
Never thought of it that way. Makes perfect senseIt's normal. Prevents the wipers wiping if say the windscreen is frozen. Saves the blades being ripped off.
Auto wipers piss me off a treat.
RainX or G1/G3 the screen.
RainX on your front screen? :banghead:
That's a no-brainer...
I also hate it when spraying the screen fluid you get this auto one-wipe after the window is wiped clean! :banghead:
Mine are weird and don't work...you flick the stalk from the 'off' position to the 'on (automatic)' position, but all they do is act like normal intermittent wipers, going off at a set interval - doesn't make any difference if it's raining or not, and the rotating dial part of the stalk does nothing to change anything. Whats going on there?!
Suggests the 'auto' part is not activated.
There is. I turned them off my old one as they drove me MENTAL !
Can't remember how to do it though. Search on here or RTFM![]()
Sorry ?!
Burny - I think you need the ignition on, engine off.. then either put the wipers on and off 2/3 times, or twiddle the intermittent thing a couple of times and it should beep at you. Same for the auto lights. Have a search.. you'll find it.
