dont need to take the caliper off mate, loosen the top bolt and remove the bottom one to swing the caliper up and tey should just slide out but if u have the caliper off it should be even easier
only for discs but by the looks of the pic they are much the same as fords and pugs, just remove the wire retainers make sure u remember what way they go on though before u do. good luck
cheers have worked it out. There is a slider holding the pads on. It needed to be hit out with a hammer and punch. cheers for the help anyway. Have a new problem see my new post
