When you remove the rear bolts theres 2 clips still holding the boot handle and diamond on to the boot. I was in a hurry and snapped mine, still bolted on fine though. Then you need to scratch the 4 lines of plastic away from behind the diamond for it to come out (thats if you were wanting just the diamond out)
Am after spraying it a tried prising it out today and snapped the diamond, av got 2 spare ones but they got 3/4 pins on as there off the front not sure if they fit, when a take the diamond off is it stuck on with some sort of glue/ will a need something to stick it back on with
when you get the boot catch off look behind it theres 4 strips of glue behind the diamond. you just need to scratch it away so it will push through. As for the front diamond i'm 100% sure you cant use it for a rear replacement. Is this what you meant, sorry got a bit confused reading ya post lol (i'm tired)
