Removing dash in a Mk 1 clio (williams 3)
One of my bulbs has gone behind the speedo, has anyone taken there dash out to replce bulbs before?
If so whats the best way of getting the beast off without damaging it?
Help, its getting on my wick already.
  20VT Clio & 9-5 HOT
easy peasy mate.
All you need to do is take off the top dash (5 star screws) and the plastic round the console. Then unscrew the two screws that hold the clocks in, get ur hands behind and unplug all the connectors including the speedo cable. And the clocks are out.
The bulbs just turn and pop out. Fitting is reversal of above. The speedo is a little tricky as there is limited room but its not too bad.
Haynes will help you too if you have one!
  Toureg vW Transporte
eh??? i just done the ones for the 3 dials in the middle tonite, and i tried gettin the main dials out but cant, i took the main 5 screws out and the the 2 at the top of the dials but i couldnt budge it, wot am i doing wrong adAM AM I MISSING TAKING SOMETHING OUT MATE?
  20VT Clio & 9-5 HOT
ahh iv just thought i think phase 2s may have some more under main clocks
ill have a look in haynes
ta mate, real gettin on my nerves, do u also find that the oil temp display, the middle of the 3 is a bit duller.???
  20VT Clio & 9-5 HOT
do u mean ur havin probs with the main dials or the 3 oil ones mate?
sounds like u have a bulb out mate. mine were all ok and i swapped the lot for willy ones. Thought id checked em all but the middle oil is dull. iv got a spare bulb just need to fit it.
  20VT Clio & 9-5 HOT
I cant find it mate. i think iv left it in the car and its at the garage...! ill keep looking though
