Me again!!
Pretty easy job. Take out the speaker which you get to by taking the small cover off easily. Remove the panel behind the mirror and the long panel next to the window. Then unscrew the handle, disconnect the cable. Now unscrew the grab handle slide it towards the back of the car and lift it up, disconnect the window wires. Now unscrew the 4 screws at the bottom of the panel. The only thing holding it in now is a couple of plastic clips and balck extremly sticky stuff. Thsi is the tough bit to take off as it is sttrong as! Just work slowly around the panel and with patience itll be fine. Obviuosly refitting is just the opposite.
