That bolt that has snapped off. Well I've been told I need to get the hub off and take it into an engineering garage. Is it easy enough to do? Any technical guides?
Easy enought to remove undo the big 30mm nut in the center of the hub/wheel then undo the two bolts which hold the ball joints to the wishbone undo the one bolt (might need ball joint splitter) to undo the bolts which holes the stearing arm to the hub and then undo the two bolts which holes the hub to the shock. Don't forget nto udno the brakes 2 bolts again to remove the whole brake assembly
