removing glovebox 192
Car  monaco 172
Im familiar with removing the dash, however i am wanting to run some 0awg cable though the firewall but i cant for the life of me see how its going to go through the standard grommet which is behind the glovebox.
So my plan is to remove the glovebox and then use a stepped drill bit to make a new hole with a grommet for my 0awg but i cant work out how the glovebox comes out. Does the dash need to be removed first?
Shouldn't do mate. The screws holding it in are behind the dash strip, and from memory another screw on the far left behind the door rubber?Hope that helps.
