R redroze Dec 5, 2007 #1 hello mats, need to remove the mirrors and their panel for color coding. need a guide or something. cheers, Elad.
Martin_172 ClioSport Club Member Car 182 RaceVan / 197 Dec 13, 2007 #3 inside the car, pop the trim pannel off, theres a connector, unplug it now remove the 3 torx screws holding the mirror on and remove the mirror. the glass then pops out, i just used a screw driver to do it if i remember correctly (been a while!) you can then un clip the mirror plastic cover off! EDIT: Im assuming you have a MK2 clio? that guide above is for a mk2
