Removing mk2 ph2 bumpstrips
Car  Chocolate Bar™
what the knack to removing these. i've seen the two screwdriver lugs on the underside but still cant figure out how to remove them.
do i have to pull towards the end of the door (i.e. door strip back, and rear quarter strip forwards?)
Mark
And if your gonna remove the back bumper strip like i just have, then a cloth with a flat head screwdriver in the corner and above the lugs it just pops out 1 by 1.
^^ If that any use :)
Where are the lugs on the side bump strips because i tried just sliding the strips but nothing happened?
Also how do you get the front strip out?
gonna resurect this, im having trouble removing the 3/4 bump strips, can anyone give me any advice on getting them off?!
you need to pull them towards the door mate, ie front of the car.
if your having trouble, try lifting the edge closest to the door up a little bit, as there is a lug that sits in a hole to stop them just sliding forwards whenever.
for the long 1's, pull your badges off the with a rubber mallet 1 nock with push it back by hitting it on the stick out bit. Rear just push it towards the car with your hand and hit it towards the front with a rubber hammer letting it just grip the plastic and they just come off
cheers for the info, managed to get them off just after i put a post up in here!
killed my fingers though!
