Hello, my Panda has quite a bit of plastic trim on it, and some clown has managed to get polish all over it. I want it to look like it's original black plastic colour, what product would be best to use to get rid of the white polish marks completely?
Always used a school rubber me. If the plastic is grained and the rubber wont remove the deeper residue, get vinegar, petrol or neat IPA out. All these work. Try to avoid heavy rubbing as you will end up fading the trim.
Personally i use a microfibre mate as the pile will get into the grain. You can use a normal cloth as long as its clean and dont rub to hard, just work the vinegar in.
Plastic trim is very absorbent so the best method to do use IMO is.
Heat up the trim with a hair dryer this opens the pours in the plastic then clean with some form of APC as strong as needed, noting it will remove wax from painted s**t if strong.
Now it should be clean. USe the same method to apply a trim gel for a much longer lasting effect.
^^ Using Apc is also fine but my worry is that plastic trim always has paint surrounding it. I prefer to get away with the apc route so i dont strip my waxes or sealants off.
WD40 on a MF Jamie. Plus a bit of elbow grease. Then clean them down with a decent All Purpose Cleaner. The active ingredients break the polish down. It is the same idea with Linseed oil.
