REMOVING REAR DIAMONDS?
Car  172 ph2
Im been looking on the site and cant see a guide on removing rear badges.
im guessing its not like the front where they just pop off?
any help would be good as i want to spray them :)
Need to take you plastic covering off in the inside of your boot (one hex screw rest clips). Then, theres three nuts the hold the boot handle on undo these then pull the full handle out. Heat up the glue on back of badge till soft and pull it out.
As above ^ :)
It can be a bit of a fiddle to get the boot-lock out when you get the three bolts out but nothing major
