ahh ok, you need to undo the bolt attaching the rear seatbelt which is at the bottom corner of rear door card.. you also have to undo the torx bolt which holds on the front seatbelt metal thing by the floor.. think the torx is size 40 bit. From memory I think after that it should just lift up and off though there could be something else holding it on...
