Removing seats.
Ad
  MK2 FRS
Ive got a 2002 clio. Am i right in thinking that the you have to get under the carpet to get at the fixings??? Havent had a proper look. Im sure I read that soemnone had changed the seats in theyre cup. An advice appreciated.
Adam
Tom
  i3
use the search someone has posted about aftermarket seats
but be warned it voids your insurance and makes it hard to get a good quote
(because of side airbag removal)
  Turbo'd MX-5 MK4
yeah im sure i read that the guy said he had to get underneath the car to undo some bolts.
Ad
  MK2 FRS
Im replacing them with 172 seats so insurance not really a problem as they are essentially the same seat just with leather.
I had to take out my pax seat to install an amp. The way I di it was to remove the seat from the runners by removing the plastic side panels on the seats. To remove the seats and runners you need to get under the car. There are four rubber plugs ,one for each bolt!, but you will need some fancy long socket to get at the bolts. It looked like being a major pain.
Ad
  MK2 FRS
Ive decided to swap the covers rather that the whole seats. (In the front.) Still quite a major hassle but not in comparison to swapping the seats.
Cheers everyone.
