Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Firstly remove the 90 inlet hose to allow more access, then there are just two 10mm bolts that hold the airbox in place, next unclip the side air feed hose (in front of battery), but there is another air feed underneath thats trickier to get at, but a bit of waggling will help.
Then just pull it out, but it wont come straight up, you kinda need to twist it out and youll see what I mean when you do it.
when i fitted my hillpower kit i left the original cold air feed (that goes down towards the front wheel arch)in place as well as fitting the air feed supplied with the kit.
