behind the steering wheel there are 2 pins, one on the left and other on the right.
you need to pop these off, so use a flat headed screwdriver and pop them out, once both have come off the metal holder on the back the centre comes out, and you then disconnect the connection.
Then you need a Torx 45 i think or torx 50, and remove the bolt in the centre, job done
