removing the front diamond
  liquidized RacingBlue 182
how do i go about it? or is it easy enough need to replace it once i have got new one and sprayed it... thanks
2 min job, if you can reach and get the screw driver behing the front bumper there are two screws, one at top, one at bottom. if not, undo the black "pop" screws holding the grill on and lean the front bumper forwards for an easier angle.
worst comes to worst, 5 min take the bumper off jobby :)
jamie
  Lionel Richie
front bumper has to come off, or you can remove the grille and get it out that way, its held in by 3 small torx screws
but the diamond is plastic welded (sort of) onto the black surround, you'll have to snap the welds to get it off, paint it, then superglue it back on
