Pull!
You might find it easier if the mirror is folded in?
I used a flat headed screw driver in the gap where they join to lever them off, didnt seem too difficult tbh.
A good tip i found was to fold them in towards the car when i was doing it otherwise they tended to get a bit stuck on the part that joins to the car.
Good idea
Yeah I have tried that also, seems to make no difference, just really don't want to resort to using a screwdriver or similar as I want no damage! :dapprove:
Find a screwdriver the same width as gap between the cover / main mirror bit. Place it in and twist, then move along the gap and repeat. I found it helps if you push the bit that you are twisting (if that makes sense).
Maybe they are different on the 1*2's ?? Your struggling to get yours off Daz , i struggled as well , i tried the screwdriver method and was convinced they were going to crack so gave up . They definitely don't just pull and off like others have said .
