Removing trim on a 172
  Megane R26
Well im new here. Been reading for a while. Got my 172 about a month ago.
Ive installed a new HU, now i need to run the cables for my amp. I know about the power cable run thru the gromet, but I need help running all cables down the passenger side.
I got part of the trim off by the seat, just tugged, off popped the bonnet release and was able to unclip most of the trim running down by the passenger seat. Now im stuck. It looks like I got take the rear quaters off to allow the rest of the trim to come off. Gave it a good tug, but no joy, can someone help me out? Pics would be great! :)
  Ziel Nurburgring
I didnt take off the trim just threaded it through, around the bolt and ran it under the seat. Much easier than taking off the rear quarters....
  Megane R26
Cheers Blink, and for the welcoming ;)
When you say you ran it under the bolts, did you just push it under the trim? Can you see any expossed cables?
Aslo I gotta run 4g power cable :eek:
[Edited by MrStabby on 02 June 2005 at 2:08pm]
  Ziel Nurburgring
Yeah, pushed it under the trim (think it may have been my old car that was bolted) using a wire coat hanger to direct it. No wires are exposed and wasnt to difficult to do. One of the easiest cars ive ever had to wire. Changing the front speakers is a different matter.....
  Megane R26
Ahh I see. I wanna clip it in the original wiring loom clips. Do you know if its easy to remove the rear trim ? Will the haynes manual for 2000 clios tell me? As bloddy haynes dont do a manual for the 172 :/
4g cable around 10-12mm diam!
  One with a few more
there is a haynes for 2000 on. as i have it. and all the interior stuff is pretty much the same idea for both normal stuff and 172s. its all pretty easy. just gotta hold youre breathe and tug. its actually quite tough compared to others cars ive played with
  Megane R26
Thanks for the heads up claire. Gunna give it a bash after work. Stop by the local halfords and flick thru the haynes, maybe buy it ;)
  e60 M5 -172- dciheid
i understand that there never has been a haynes manual for the renault sport manuals as i just went on and checked - is the other one still any guid? i think it could be worth the 18quid cost - any one else have it and care to comment?
oh heres the link for the catalogue http://www.haynes.co.uk/wcsstore/HaynesPublishing/images/cataloguepdf/CompleteHaynesCatalogue.pdfhttp://www.haynes.co.uk/wcsstore/HaynesPublishing/images/cataloguepdf/CompleteHaynesCatalogue.pdf
[Edited by R20 CWH on 02 June 2005 at 10:21pm]
  not a clio anymore
the haynes are good in the sense that whatever is common (i.e most parts) will be described. It is just the specifics about engine, maybe suspension and a few other bits that are not there. I would expect interior trim to be the same between a 2.0 and a 1.2.
If you want to buy it, join the club, there is a 12.5% off the list price with free delivery.
  Megane R26
Well I ended up poping into Halfords and getting the manual. Didnt really need it. Trim comes off so easily.
Cable run was quite easy, although I had to drill a hole in the passenger foot well for the 4g power.
Have realised that the OEM speakers just wont cut it. I have to cut most of the bass from them when cranking it. So next job, 4 chann amp and coaxials in the rear , and components up front. Glad I ran the extra RCAs and installed my distro block :p
