removing wax, to use polish..
I've been told not to apply polish on top of wax, so i want to sort my car out for FCS at the weekend but applyed a coat of wax last weekend, how can i remove this to apply polish etc again...
Rob :approve:
  CLIO V6 MK2 255
Rob :approve:
go to you local paint dealer by a litre of wax and grease remover and use that. you wipe it on with one cloth soaked in it then wipe it off with a clean cloth, only do one panel at a time because it dries very quick. i use it at least once a year to remove all the old crap which is on the car and start with a clean paint only finish. you will find it will make a difference.
martin
just won best 2000 car at the RENAULT WORLD SERIES
  titanic killer
Rob :approve:
martin
Will that be like a panel wipe chemical that bodyshops use before spraying a panel?
  PH2 172
Is that like a traffic film remover if so works got loads of that so might ask for some so i can try it at weekend
  Skoda Fabia vRS
woah !........tfr and panel wipe are different products !
be careful using tfr, very careful, look at the dilution ratios on the bottle
as above though, polish will remove the wax, are you doing it by hand or machine ?
