Renault 1.5 DCi Turbo part numbers
  MERCEDES CLS AMG
A handy list of turbo part numbers and oval plate numbers which correspond to the mentioned vehicles. These turbo's do fit other K9K variations ( of which there are over a hundred ) the oval plates are just rough guide lines to help you on the Dialogys. The part numbers given are the Borg Warner number ( k series ) and not the Renault part number. The Borg warner part number can be found on the blower housing ( blue / yellow / red badge )
Engine type turbo part number model / oval plate
K9K 700 * 5435 970 0000 * Kangoo FC07
K9K 702 * 5435 970 0002 * Clio CB08
K9K 704 * 5435 970 0000 * Clio CB07
K9K 710 * 5435 970 0000 * Kangoo FC09
K9K 712 * 5439 970 0027 * Clio CB2G
K9K 714 * 5435 970 0011 * Kang FC1E
K9K 718 * 5435 970 0012 * Clio CB3N
K9K 722 * 5435 970 0002 * Meg CM0F
K9K 724 * 5435 970 0012 * Sce BM1F
K9K 728 * 5439 970 0027 * Sce JM02
K9K 732 * 5439 970 0030 / 0070 Meg CM1E
K9K 740 * 5435 970 0011 * Clio CB3M
K9K 750 * 5439 970 0000 * Clio CR0V
K9K 764 * 5439 970 0030 / 0070 Clio CR0H
K9K 766 * 5435 970 0012 * Clio CR0F
K9K 768 * 5435 970 0011 * Clio CR0G
K9K 780 * 5439 970 0030 / 0070 Lag BT0A
K9K 802 * 5435 970 0012 * Kang FW0B
K9K 804 * 5439 970 0030 / 0070 Kang FW0C
K9K 706 * 5439 970 0030 / 0070 Kang FW0F
K9K 832 * 5439 970 0030 / 0070 Kang BZ0B
Oval plate numbers
If they start with a ......
C - 3DR
B - 5DR
D - COUPE
E - SOFT TOP
F - MID SIZE / LARGE VAN
H - FLAT BED
J - PEOPLE CARRIER
K - ESTATE
L - SEDAN / SALOON
S - SMALL VAN
