Renault Koleos Injection Fault
Mertin
  Ph1 172&Ph2 172 Cup
Looking for any renault techs / someone thats had experience with Renault Koleos
Car started and cut out and then failed to start last Monday, and showed injection fault on the dash. Had sat for 2 days, unmoved in frosty weather.
Pumped fuel primer bulb a few times and started fine and has been fine everyday since. Planned to get the car serviced incase fuel filter at fault, whether its sludge or water in it that had maybe frozen and lost prime.
Faults then returned again today, I cant investigate as away from home for 2 weeks. Will try the primer bulb again and hope it goes, is there any common faults with these?
Hoping it is something simple before going down fuel pump route etc.
Will be getting it onto diagnostics as soon as possible, however is it likely to have stored a fault code if its then runs ok?
