Renault OptiLine laser check
  Black 182 + Recaros
Just spoke to Renault regarding a laser alignment check. They do something called an OptiLine check. It takes 2 hours and costs about £150. Bl**dy expensive.:cry:
What do they do that takes 2 hours ?
As anyone had this done ? Do any other national garages provide a similar service for less?
  R26
lol, the technician takes his pals out in your car for a 1hr 45 minute blast while you sit in the garage drinking coffee then returns to do the business after 5 minutes of letting the smoke clear from the thrashing hes given it.
:cry:
Djw John
Scotland - South
Theres a local specilist to me who does absolutly evrything for £32.50 in about an hour or so, I wouldnt give it to Reno for that job.
  Black 182 + Recaros
Thought it was a rip off. The problem is finding someone else that can do this. Anyone in the Midlands or Staffordshire ?
  The Jinx
To get a laser alignment check for under £80 is unheard of I think. Remember its different to just getting the tracking done.
  Black 182 + Recaros
scooby -
Would be willing to travel to Northampton. Do you have the details on the garages you used. Thanks.
  Silver Fabia vRS
Quote: Originally posted by mike8579 on 24 November 2004
Sorry, but I cant see 20min job being laser alignment.
Well Im sorry but it is, ring them if you want. Company is STS Wheel Alignment and the phone number is 01234 269800, and its the only thing they really do. All the major car dealers in Bedford use them, including BMW, Volvo, Land Rover, SKoda and Chrysler.
  Lionel Richie
Northampton Motorsport tel 01604 766624 and ask for Roger Fowle
hes expensive, but knows his sh*t!!!! £94 for a set up
geoff there are SO MANY different tracking/alingment places out there ranging from your £25 quickfits upto you £100 + motorsport companys
youd be amazed at how far from 100% straight a £25 quickfit track really is!!! and they use lazers, but i reckon they must be special bent lazers
problem with those types of setup are that you have human error built into them (im on about the one where the lazer shines onto the board)
Northampton Motorsport are 100% computer, so it cant be fcuked up
  Silver Fabia vRS
The one at Bedford uses a Hunter (if I remember correctly) laser alignment which is all done through a computer. You put in details of the car year and model and its does most of it for them!
  Black 182 + Recaros
Thanks geoff. Bedford is a bit too far for me. I guess they could only produce those detailed reports using a computer system. If someone says "yes thats okay" then they arent doing a laser alignment check. I am after the full report.
  The Jinx
Nah. Not having it. Most dealerships charge in the region of £150.
It took more than 20mins to do the tracking on mine and that wasnt a full on laser set up. It only did the horixontal alignment. The vertical alignment should be done as well, and at both ends of the car.
Thats going to be more like an hour of a job.
  The Jinx
Im just intrigued to know how it only takes 20 mins to do the vertical AND horizontal alignment of 4 wheels? I assume the Optiline is a full geometry check you see?
  Black 182 + Recaros
Geoff,
Perhaps ESCOBARs post was more accurate than we thought. Give or take 5 minutes ;).
"lol, the technician takes his pals out in your car for a 1hr 45 minute blast while you sit in the garage drinking coffee then returns to do the business after 5 minutes of letting the smoke clear from the thrashing hes given it."
  Lionel Richie
Quote: Originally posted by Jason C on 25 November 2004
...a good motorsport mechanic might use string - dont be put off.
ok, but ill rephrase that for you!!!
...a good motorsport mechanic might use string, but they wont win any races!!!
Geoff, HUNTER is the best gear you can get!!!! so thats a DAM good price!!!!!!
  111s
If its checked and found to be ok why should it take any longer?
  The Jinx
It would take that long just to put the gear on. Ive since looked at websites for places that offer this service and they all say at least an hour.
I suspect that the 20min job is simply a tracking job. to align 4 wheels the front wheels are set to be in line with the rears to put it simply so only 2 are actually adjusted. However a full geometry set up is a whole different kettle of fish.
My alignment took 20 mins (after they freed up the track rod ends).
I thought you could only adjust the front tracking on the clio so whats the point in paying a fortune to measure anything else unless youve had a bump.
