as some of you will have heard my engine died and I sourced a replacement cheap with low miles from a 2006 reg clio campus. I have removed my engine and noticed other than the odd cosmetic changes I can't find where certain bits go... (ecu, coilpack etc)
I was then told by my friend who is a mechanic when he popped round after work when I had both engines side by side that some of the sensors attached to the newer engine are different (look the same to me :S)
what were the changes to the newer d4f that were made? and would I still be able to fit this newer version to my gearbox, (gearbox still being in the car I ran out of time before it got dark to compare bolt patterns...)
did search and there seems to be no mention of someone changing the d4f and encountering this.
thanks
thanks
