reset check imisions light ???
Car  clio 197
can any one tell me how to or if you can reset the check imisions warning light on the dash.
i disconected the grey plug from what i thought maybe the acustic valve.went for a quick drive round the block but the warning light came on.i pluged it back in but light wont go.
i phoned renault and they want to book it in and have the car all day just to reset it ?
any help please...
car drives fine and they said will be ok to drive till its reset...
thanks...jase.
ecu reset might do it. Do a search for "ecu reset" the thread will be a week old at the most.
Certain error codes clear themselves after 3 clear starts. Give it a couple of days and take it from there.
so to reset the ecu i disconect the negative terminal of the battery for 20mins.
will i lose my remap by doing this ?
You can disconnect your ECU and it does sometimes clear the error codes. You will not lose your remap this way.
I would try 3 clear starts first. Take it out, drive for 5 mins, stop for 30 seconds then restart. do this 3x and I reckon it should clear the error unless something else is at fault.
just to let people know this works on the 197.
i disconted the negative on the bat for 20 mins and it cleared the fault.
but came up with traction disabled,to it for a spin and 100 yards up the road traction reset itself.
cheers for all the help....:star:
a bit peed that renault wanted to have the car all day though just to do that.:S
It also works if you leave it for couple of days. Mine usually goes off after its restarted around 10times.
The light also went off by itself after a while when the de-cat was fitted.
Can the valve on the 197 not be disconnected then?
it didn't seem to make any difference to the sound or power.so tbh wouldnt bother.
i left it connected and got a mate to rev the car and couldnt see the valve even moving,but tbh dont know if it should when its stood not in gear.?
On mine it did sound a little different with it off. Didn't really have any noticeable gain in power though.
