http://www.speedwaymotors.com/p/1377,13_Residual-Pressure-Valve-RPV-2-psi.html
I would think they are fitted to cars with 4 pots is to keep more fluid between the valve and the caliper as the 4 piston calipers now need more fluid than the single standard caliper, meaning when you press the brake pedal the master cylinder will not need to travel as far.
Only a guess but could be wrong.
yes please. il swap you for my engine?
