mharvey
Hi all,
Bit of a strange one. Remapped the car with an RSTuner a couple of months ago, all was well.
The other week I then had the car running on 3 briefly, went to pull over and it sorted itself out before I could. It's happened once since but again only briefly and there are no fault codes relating to the missfire.
Then the other night I ran into the rev limit (which is increased due to the map) car was warm and I only ran into it as I hit a slightly greasy patch of road.
As I did the car went into limp mode, I have tested since (ran into limit on purpose, never advisable but I wanted to check if the limp mode was related) and it has done the same thing again.
Any suggestions?
Thanks in advance
Matthew
Any suggestions?
Thanks in advance
Matthew
