Rev sensor on a f8q engine
Do you the top dead center sensor?
Its between the engine and gearbox up at the top
Resistance ≈760 Ω at 20 °C
  CB600FS
More than likely its the connection on the back of the actual rev counter mate if thats what you mean?
Does it just go to the 0 mark and do nothing? Try hitting/tapping it
  Renault clio mk1 p3
The rev counter it self is fine as i replaced it with a spear one i had, even with it changed it is doing the same, it does not seem to be giveing the correct readings red lines when changing gears or pulling away.
If the car is not moving the needle sits in the middle of the dial bouncing backwards and forwards slightly, so this is why i think it may be the sensor or something like that.
