reverse crunch
  clio 172
hi all has any 1 else got this problem, when ever i put it in reverse it crunches??
any 1 got an explanation for this?
thanks
  Mk5 golf gti
they are straight cut gears so tend to crunch anyway i suppose :rasp:
do you mean when you are totally stationary.you sure the clutch is fully depressed?
it does happen
  A3 2.0TFSI QUATTRO
mine does it with the slightest movement on and it was the same in my corsa i think its something to do with the lift up reverse
  Cup and R6
as above does it do it when moving or stationary?
it'll always do it when your moving due to reverse not having a synchro
