Reverse lights not working
Car  clio 1.4RT
HI,
As title says ive no reverse lights working, replaced the bulbs and also checked the fuses all ok....
what else can i check on a 98 R reg mk1 1.4rt clio???
Its on the bottom of the gearbox, near the inner NS driveshaft boot. It should have a brown or green connector going to it. 22mm spanner to remove it, should have them at motor factors.
Cost me about 12 quid from GSF the other day. Easy enough to replace through the n/s wheel arch with wheel off. The gearbox oil will drain though so do it quickly then make sure you top it up after!
I just went in and said "one reverse switch for a Clio please". They pulled one out. Assuming not everything is on their website. Worth giving them a ring tomorrow.
Just happened to come across the invoice, bearing in mind this was for an 03 Clio (quite possibly all the same though), here's part no:
7700-422-630. £11.04 inc vat.
Ring them tomorrow and tell them your car/year.
it'll be the switch on the gearbox I had the same problem on my last car for 3 years and only got it fixed just before I sold it!!
