Revin Engine
  ClioSport 182
Hey,
When i start my car seems to be revin quite high bout 1500rpm normally down at lil 1000rpm and wen i stop slow down n stop the car revs up n down for few seconds.
Does anybody know wot this cud be.
  RenaultSport clio 172
SteDonaghy said:
Hey,
When mine forst starts up, it goes to about 1200 to 1300 rpm, then after a minute drops to about 900, sounds like a idler problem
  ClioSport 182
say when its cold noticed it more but even after while still does it,
if it is the throttle sticking how can its be solved
from cold - its the automatic choke thing ...........normal .
if its still doing it after u need to ask fred ?? spray wd40 on it ?:quiet:
  172 cup'd extreme
what car is it?
could be a number of things :
>electronic throttle possition sensor
>throttle cable
>mass air meter
>leak in the vac pipe
>or knowing renaults most prob a lambda sensor
  ClioSport 182
16v_jon said:
what car is it?
>throttle cable
>mass air meter
its a 1999 T reg 1.4 8v Rt Clio
  ClioSport 182
16v_jon said:
does the idle settle down or is it always moving up and down when the engine is idling?
It moves up n down most of the time, only jus recently happennin,
It happened in the past then it was fine and it when though phase of the idle not stay hig enough the engine cut out (in the cold)
  172 cup'd extreme
does it start ok ie: you dont have to put your foot on the gas to start it first time .
i would say its just the cold weather and the engine is compensating nothing to worry about unless its cutting out or reving wildly
