Revs limited to 2500 - limp mode
Hi, I guess I should have posted this question in this section and not the other one - sorry.
A friend of mine is having issues with his Clio 172 53 plate. Wonder if anyone can help please ?
Car: Fully warmed up, full tank of fuel, and all fluid levels perfect.
Symptoms: Whenever I try to rev the car past around 5,500rpm’ish all power drops. The revs get stuck at about 2500rpm and fluctuate around that.
When this happens its totally unresponsive. There's nothing I can do other than turn it off.
After a restart its back to normal. But if I rev it to about 5,500rpm again exactly he same thing happens.
The warning lights seem to be on for:
1) Traction Control
2) Electrical Fault? (the middle light, second up from the bottom looks like a heartrate monitor).
3) Service Light
Does anyone have any ideas of what this fault could be or if it’s a common issue?
Thanks,
AJ9939.
Thanks. Did a search before I posted. Came up with anything from a wet throttle body, faulty throttle peddle, possible throttle peddle wiring problem, throttle position sensor etc.
We'll check that lot today, but I posted the Q to see if there are any other common faults that can cause this that we could check out before taking it for diagnostics.
I had this problem when my Lamba sensor was f*cked, it was the main stream oxygen sensor, might be worth a look
Update - Took throttle body apart and cleaned it, and took all connectors apart and WD40'd them.
Put back together, and so far so good. 3 days of no issues.
