Inferno 182 & Saxo
On my 182 got a little issue - when its cold and been sat for a while I come to start it and wait for fuel pump to prime, its starts up and the revs hunt a bit between 500rpm and 1000. This morning it idled for a second then it cut out as the revs dropped, which it hasnt done before as the revs usually rise back up to normal cold idle speed. A dab of throttle however makes it pick up and idle properly.
Could this be CTS or some other sensor? I have noticed its a bit juddery/hesitant when cold but once the temp comes up off the stop its fine.
I do have a small exhaust leak from the manifold to cat joint but I'm sorting this on the weekend with the genuine Renault kit and shouldnt have thought that would have any bearing on it?
If anyone has an RS tuner to come read the fault code in the west midlands i'll sub you some dosh!
