Revving higher when clutch is pressed (Lag 2.0T)
When changing gear while accelerating fast, when I press the clutch down the car revs higher, as if I haven't taken my foot off the accelerator properly, or as if the throttle by wire is very laggy. Is this a problem or just the way they are?
Also what are the common causes of low mpg on these engines if anybody knows?
  Clio 197 BMW Msport
That could be the clutch slipping mate. So maybe it needs a new clutch or the pressure plate tightening.
