every time i start the mota, the revs rise to around 2000-2500rpm for a second and then idles normally, is this the throttle cable cos its a bit slack, or sumin else?
If its a 1.4 Spi then when you switch off you will have cable slack as the stepper motor opens the throttle ready for the next start which causes it to rev up.
A 16V shouldnt rev up.
Also your slack cable causing it to rev amused me.
Now you know, if your feeling bored go out take the air box off. Start the car then turn it off whilst watching the throttle arm, when you turn it off you will see if move.
