Roll Cage.....
Car  Fiat Coupe 20v turbo
Any one know how much a decent roll cage will weight? I have been looking at a Safety Devices cage rather than a show cage. Dont really want to strip all the weight out then put a 50kg cage in.
ill tell u later, iv got a safety devices one in the garage mate. i think it weights about 20kg. bt ill let u know for sure!
Cheers, have to go on diet to make up for extra weight! Adam how much did you pay for yours if you dont mind me asking?
Ummm, sell the valver and get a willy 2 or... get a new roof skin for the valver and remove my sunroof.
Hmmm, you dont have to get a cage just dont crash! Also remember if you get a Williams you are not ALLOWED to modify it in any way as it is perfection on Michelin Pilots.
Th cheapest and best place i have found is http://www.motorsportparts.co.ukwww.motorsportparts.co.uk.
The Clio Mark 1 cages are indicated below:
Renault Clio Mk1
Bolt In Cage
Multi Point Bolt In Cage
Front Cage
Rear (No Diagonal)
Rear (Fixed Diagonal)
Rear (Removable Diag)
Rear (Road Use Only)
Door Bar
Front Cage
Front Triangulation
Door Bar
£175.95
£208.92
£238.08
£302.56
£136.25
£35.00
£177.55
£245.12
£139.12
£38.42
Renault Clio Mk1
CDS Weld In Cage
CDS Weld In Kit
£650.00
Hope this helps
bollox is that cheap !!!
i got mine direct from saftey devices for just over £100 and that was before we got a club discount.
mine was a saftey devices cage wich i the same as the rear with no diagnal.
now this place is nearer to me than s/d (5 mins down the road) is but i still went direct and saved money
