marc1330
Hill lover
Im a bit puzzled with my gearbox if you select 2nd sometimes you can get a sort of mechanical notchy feeling. Also when in 2nd if you put slight pressure on the stick moving it to the left you get a horrible sort of meshing feeling through the stick. I can only describe it as what i have experienced on other cars as a feeling like the linkage is touching the exhaust
At first i thought it was the linkage catching underneath but it does not seem the case any ideas :S
