ROUGH IDLE AND STALLING WHEN ENGINE IS WARM
  Clio Sport 182
My Clio sport 182 has a rough idle and stalls/cuts out when stationary once it gets warm. Engine seems to run fine when it is cold.
I've had a look and seems it could be a number of things ranging from spark plugs, lambda sensor or idle control valve.
Where should I look first or could there be another reason for the issue?
I've owned the car for a year now and the diagnostic port has never worked so don't have any codes to work by (will get this looked into at some point)
