Rough/Low RPM Unstable Idle
Anarkistic
  Clio RS 172 Ph1
There seems to be a lot of discussion about rough idling on 172s, so as a newbie to the model I thought it best to stop chasing potential fixes and just grab a video to show you folks the way it behaves. In all it's struggling, juddering glory.
That way y'all can hopefully tell me if it's totally normal for a 172 (phase 1) or not. I hope it's not, because it sure doesn't seem healthy. If it's not normal, if you have some idea as to where I should look I'd be grateful!
(The rattling sound is from my exhaust mount that's loose)
Things I have replaced include the TDC sensor, Lambda sensor, ICV, throttle body, spark plugs, coil pack, HT leads and fuel filter. I have also had all injectors refurbed and tested, they're sweet as. No codes except the ABS sensor, no knocking, no misfires, lambda and MAP readings look spot on.
The engine is cold in the video.
Grateful for any feedback!
mumpy
  Clio 172, WRX STI
Does it fully smooth out once warm, or does it always feel a bit lumpy? Can you check fuel trims?
Darren S
Does it hunt about the lower revs when you pull up at traffic lights and the like, when warm?
Replaced both of the oxygen sensors in mine and that fixed the problem outright. Almost felt like it was about to stall at times, regardless of how cold or warm the engine was.
mumpy
  Clio 172, WRX STI
On mine, after doing everything to it (all ignition related components replaced + ron 98 map that raises idle a bit) and also bringing it to Alex for a timing belt etc. runs quite smooth now even when cold. A lot better than when I first got the car.
Anarkistic
  Clio RS 172 Ph1
I've heard mention of an improved map that helps smooth out the idle amongst other things. It just seems that a fast idle of ~700rpm right immediately after a cold start seems not very fast :unsure: For a moment you see it bump up to 1k, but only for a second.
Will check the fuel trims, hopefully that shows up on my scanner, most things seem to. What should I be looking for there?
ex-Chinese Dave
Mine was a bit lumpy when cold even after a standard map from EFI. I had a new OEM spec exhaust fitted and its miles better now.
Yarp
  182 Turbo, E46 M3
Mine idled terribly and the front O2 sensor got it back to usable. Only fit Bosch though - others don't always work.
I agree though, the idea is slightly too low. When I turbo’d mine I’d often end up with it cutting out coming to junctions when the revs dropped because it was so low it couldn’t drag enough air through the boost pipes.
It’s a properly category 1 bodge but a T piece in one of the vac lines with a new bit of hose and a couple of small holes drilled in it does the trick to raise the rpm at idle. That’s definitely not how I fixed mine, honestly 😇
Anarkistic
  Clio RS 172 Ph1
I had hoped it was something as simple as the o2 sensor, I replaced that with the Bosch one already. It seems to be working properly, judging by the ECU readings it gives.
I did refit the OE cat too, it had a decat in it before.
182Trev
  Clio RS182
Mine's always idled lumpy (a 182), did improve slightly with the usual spark plugs, leads, etc. changed, tried a new MAP sensor from eBay, which made no difference, so refitted the original one with some PTFE tape to seal it and that improved it a lot (and cleared the code), but I just live with the idle. Did hear a rumour it's to do with the cam's in these cars making them idle lumpy, not sure how true that is though.
Now its a bit colder it hates revving for the 1st 20 seconds or so, so I wonder how the auto choke works on these....or if that's an ECU thing, in short its down to these cars character 😁
Brigsy
  T.Turbo
Worth resetting the adaptives on the ecu. Wonder if the icv adaptives can be reset on ph1.
As for hot idle, will always be a little bit rough due to the cam profile. Bumping the idle up to 900rpm on a good map makes it smoother. Also a good map will sort out the spluttering from cold.
Brigsy
  T.Turbo
s**t cold running is usually due to the cold start mapping. Stock cold start has quite a bit of ign r****d to warm ths cat fast. No choke as its not a carburettor, ecu controls/enriches the fuelling on cold start using coolant temp.
Anarkistic
  Clio RS 172 Ph1
I think you can, I saw something to that effect in Renolink but it's all in French so 🤷😂
Interestingly when it gets up to operating temp, the idle is even rougher than cold, as the rpms are lower. Sitting in the car it's vibrating so much you couldn't hold a can of drink 😅 Also interestingly I note the OBD shows an rpm of 900 but the needle shows about 650, maybe that's expected 🫤
Brigsy
  T.Turbo
If obd is saying 900 id go with that. The rev counters can be quite far out.
Clip might be better to see if you can reset the adaptives as itll be in english. The french shorthand on Renolink is a nightmare sometimes :LOL:
Cam timing defo right?
Anarkistic
  Clio RS 172 Ph1
I can't say 100% on the cam timing, but I know it's belt and dephaser were done just before it went into storage for a few years, so I have to make the assumption for now that they were done properly 🤞
Clip does sound like a great investment over Renolink, but I'm finding an absolute minefield of options and version numbers and prices and all sorts and I've yet to work out what I'm supposed to get for a Ph1. Open to any suggestions!
Brigsy
  T.Turbo
Map sensor readings on idle will give you an idea if cam timing is out. Should see 400mbar on idle from memory. Might be chasing your tail a bit if its not verified correct with the relevant tools.
Renolink is mega on the newer renaults, but for clio2 clip works great. Mines ancient v176 which is very stable. Never tried any newer versions.
