RPM is low on cold start
Car  2012 Clio RS 200
On cold start the RPM is low, below 1000 about 800. I have to hit the gas piddle gently several times so the RPM jumps high and gradually drops when the engine gets hot.
I don't think this is normal? Is it?
2012 Clio RS200 III
On my Phase 1, mines about 900rpm cold start, and drops to a tadge over 500rpm when warm
Seems to work fine
(If the gauges are accurate that is)
Disconnect the battery . Use a brake cleaner spray to clean. After cleaning ,on the first start the RPM me be higher but after some miles will be ok (750...850 RPM) .
I have a carburetor cleaner spray handy, will it do the job?
