RS focus lime green?
Car  PH2 172
Is this a easy enough colour to spray. Amd can you get it in a can or does it have to be sprayed out a gun for best results??
Can't see it being different to any other colour. A can will be fine for small areas, get a compressor for larger areas.
It'll be easy enough to spray, as long as it's a bit for your Clio. If it's a bit for a Focus then it won't match worth a fook out a rattle can. It's probably also a 3/4 stage pearl so I'm not sure how that will work with rattle cans.
Liquid yellow is a 3 stage mate, not sure about the rest of them.
Ford Electric Orange (ST colour) is also a 3/4 stager, so the green could be aswell, generally the "special" colours like that are.
