Hey folks, i have an issue with my lumbar support which I presume may be quite common.
I have sourced the issue to be the end of the cable coming free, so rotating the spool on the side just winds the cable up etc. Is there an easy way to fix this? Cheers for any help!
After tidying up the frayed end of the cable I was able to get it through this jobbie, tighten it up then slot it back into the bracket. Had to pry the bracket wider with some pliers. I can't fully wind up the support due to the loss of the original nipple and the new one being further down the cable, but its certainly better than nothing.
