Rs tuner - 'cannot connect to ECM'
Has anyone had this problem before? it's on a ph1 172, ignition on only, try to connect it to the car it's days the above but then the bottom of the window comes up as connected.
It also reads the fault codes but cannot delete then, and it is unable to read the ecu.
Anyone any idea's?
  182
What are the fault codes? The one about throttle position everyone gets so don't worry on that one.
But iirc the ecu has to be clear of all fault codes before before allowing you to do anything. Plus as fatty said above you need it to be unlocked to be able to read the ecu. Only diagnostics can be used otherwise, also if the other fault codes are on the ecm/pcm??? You need another module to access that area for the likes of airbag and abs faults
  182
No, it hasn't, it should still be able to connect to my car though and delete the fault codes?
Yes it should. There is a certain tick box during installation of the computer software on the laptop, that needs selecting. But i can't remember where abouts it is an a fair few have had the same problem on here.
Cheers Martin,
There is no throttle position one with it being a ph1 funnily enough, there is the carbon canister one and immobiliser link that are in orange and a abs and O2 one that are in red?
I didn't know you needed them unlocked to 'read ecu' I will buy the unlock code today and install it on another computer making sure all the box's are ticked.
  182
Lol my bad yes ph1 and cable throttle;).
But as said you also need to remove those fault codes. But if you don't has the optional extra "abs module" you shall struggle.
Could also be old faults that have been rectified but not removed.
