RS tuner fault code
Car  192'd BG 182 FF
Hi guys, just recieved my RS tuner and had a little play, im getting a rear oxygen sensor fault, car is de-catted so i understand that. My question is will i be able to change maps while this code is present? Thanks, Lee.
Erase the codes(02 sensor ones etc) then map it.
Aftermarket steering wheel?
Thanks for the reply, no i don't have an aftermarket steering wheel, howcome you ask?
To erase the codes do i just use the erase DTC from ECM button?
Thanks, Lee!
