Rs tuner help!!!!!
imprezaworks
Car  Mk5 Golf GTI :)
So plugged it in and all that jazz and came up with trouble codes which I tried to delete. But it won't let me delete the front 02 sensor that's at fault, what can I do? Buy a new sensor maybe? Also looking at the file its running software 6400 and calibration 5402, is that the standard map? I hate computer stuff :(
6400 / 5402 is standard.
To update you will swap to 6500 software then load the new calibibration.
If it wont let you delete the code then it means its still a present fault, so you need to fix the fault then clear it again.
