Cub.
Read ECU - then follow instructions on screen.
Read Cal - then follow instructions on screen.
You'll have to save an .RST file after reading the ECU. Then a .Cal file after you have read the Calibration.
Once you have saved these, click write ECU and follow instructions. It will ask you select a file, pick the .RST file Henk sent you (you need to save it to your laptop beforehand).
Once the RST file is successfully written, connect to the ECU again, then write the .Cal file. Follow the instructions, then select the .Cal file Henk sent.
You need to have the laptop plugged into mains and the car on a 12v charger ideally. Can take up to 40mins.
